It is currently 05 Aug 2026, 05:31
Pre-season work
by shibbs » 07 Apr 2018, 20:20
This is quite good timing for me. Scrubbed the boat down, well, jet washed and gave a clean, it didn’t come up overly clean to be honest from sitting through the winter.
There are still marks that will come off with a good soapy wash, any advice on other than that prior to polishing?
I don’t want to polish to clean dirt off unless this is a good way to do it?
It will need a good polish either way as it’s not very shiny at all! :cry:
Any advice?
by argonaut » 07 Apr 2018, 21:21
You can go over it first with a a gellcoat cleaner
http://www.meguiars.co.uk/shop/heavy-duty-oxidation-remover-473ml
This will remove any grime & oxidation, and can remove old wax, and remov3 fade ... they do a more aggressive one if gelcoat is really dull.
by shibbs » 07 Apr 2018, 21:25
Excellent, thanks very much, will give it a try then see how it polishes up.
by MartynG » 13 Apr 2018, 07:07
I thought I would be missing the start of the season by having the boat ashore . However we haven't missed much at all. Work in progress - should be all done this weekend.
On lift out
After some cleaning work
by ColinR » 13 Apr 2018, 10:42
That's a good cleanup job there :D
Should add a couple of knots.
A good polish up is very satisfying isn't it.
by shibbs » 13 Apr 2018, 20:28
A really good transformatin there! Looks good. 8-)
Very satisfying! I launched today, all going well!
by ChrisH » 13 Apr 2018, 21:20
MartynG wrote:I thought I would be missing the start of the season by having the boat ashore . However we haven't missed much at all. Work in progress - should be all done this weekend.
On lift out
Looks like new drives. Amazing
