It is currently 05 Aug 2026, 04:28
Mercruiser 4.5L
by betty boop » 22 Aug 2017, 08:24
argonaut wrote:On my trailer, I move winch post forward about 4" from where it was , moved the rear Bogey's back so the last 4 rollers were just under the transom.
Did not have to move axles - but that would be an option.
If I recall on the SBS u cant move the axles as they are bolted through the frame section so the only load shift is back & forth on the winch stop.
by kwil » 22 Aug 2017, 08:53
betty boop wrote:If I recall on the SBS u cant move the axles as they are bolted through the frame section so the only load shift is back & forth on the winch stop.
Everything is adjustable on any SBS trailer produced in at least the last 15 years. Winch post for height and position, front keel roller for height and position, all cross beams and roller sets and the axles.
Keith
kwil
by betty boop » 22 Aug 2017, 10:22
15 years. - explains why mine had big bolts through the axle to frame then
by Ianfs » 22 Aug 2017, 11:22
This has really gone off topic.
It's a fascinating and knowledgeable discussion but could I ask you guys to open a new topic in the Trailer forum or tack on to Argonauts discussion about Trailer recommendation, it's spreading the chat around a little and I'm getting giddy keeping up. :?
I'm sure Argonaut doesn't mind the hijack but it does diversify from his original discussion.
Thank you. :)
