It is currently 05 Aug 2026, 04:28
Metal polishing
by Warpa » 07 Jun 2017, 16:18
Ok so it's not a prop but I thought I would try my hand at metal polishing instead of gel.
Subject for this was my work hammer, could make a stainless prop look like a mirror.
Warpa
by _Ed_ » 07 Jun 2017, 17:36
Dangerous game this... You'll want to polish everything.
by ian h » 07 Jun 2017, 20:13
Like the end result. How long did that take ??
I have 4 props that would look good if polished :D
by mlines » 08 Jun 2017, 07:01
Ian,
We use Bracknell Metal Polishers which is not too far from you.
by betty boop » 08 Jun 2017, 07:42
_Ed_ wrote:Dangerous game this... You'll want to polish everything.
yes I was told to 'get a life' after polishing saucepans and the kettle after I discovered polishing paste last year. :oops:
by Warpa » 08 Jun 2017, 09:17
It took maybe a couple of hours using an angle grinder. Flappy discs to take out the imperfections, fine grinder and a polishing wheel.
No metal polish involved.
Warpa
by Warpa » 08 Jun 2017, 09:23
Martin how much did they charge you to do a prop?
Ian I'm sure we could sort something out :)
Warpa
by mlines » 08 Jun 2017, 12:24
First time was £30 per prop (duo-prop so £60). This is the change shown in the picture.
Subsequent annual clean was £20 per prop (ie. £40).
by ian h » 08 Jun 2017, 20:47
Martin,
That is amazing finish. apart from the "Bling" factor does it actually add any speed or does it reduce ?
by mlines » 09 Jun 2017, 07:59
Probably only in my mind!
Clearly a really fouled prop will affect performance but whilst ours originally was heavily coated on the surface, it was only the surface.
However now they are polished they seem to be self-cleaning (I guess the surface is too smooth for things to attach to it). We didnt even need a polish at all at the start of this season.
