It is currently 05 Aug 2026, 05:40
How can you do this to a sportsboat!
by Xboatboyx » 23 Mar 2017, 19:11
Poor old Joka Tu getting antifouled for her new owners.
by betty boop » 23 Mar 2017, 20:32
Xboatboyx wrote:Poor old Joka Tu getting antifouled for her new owners.
- did they score the hull when applying the anti foul? just wondering as I need to remove mine (large lumps are coming off anyway) but cant make out if the underneath is scored or if its just painted on gelcoat.
by Xboatboyx » 23 Mar 2017, 20:38
I would guess they sanded the hull to give it a rough surface for the primer paint to stick onto ( grey paint in pictures 2 & 3) then antifoul applied on top.
by Bigplumbs » 24 Mar 2017, 06:23
I know it is sad but sometimes it has to be done
by ColinR » 24 Mar 2017, 09:02
Nooooooooooooooooooooooooooooooooooooooooooooooo.
All those hours polishing sob sob.
by Ianfs » 24 Mar 2017, 13:35
At least its a decent colour, some I've seen recently should be banned. :lol:
As James has said, how could you do it? But then, there are some cheap moorings around. I think its either the Avon or the Stour, Bournemouth Water have some silly cheap river moorings.
by ColinR » 24 Mar 2017, 15:26
Antifouling a sports boat just devalues it. And keeping a sports boat on a mooring just means it gets covered in crud and gets bashed about.
I assume they've decided to move from Saxon on the stack and are moving to a pontoon at Shamrock. Odd decision since the cost is near enough the same.
I also wouldn't keep the camper cover on for a long period as it leaks a bit. Better to use the tonneau cover which is tough as old boots.
by Bigplumbs » 25 Mar 2017, 08:13
If they can get a fairways swinging mooring it is very good value but you have to antifoul. I just got mine for this year at £90 for the full year. Then a tender and bobs your auntie
My boat had already been antifouled so no biggie. I would never antifoul my 17 footer though
by argonaut » 04 Apr 2017, 20:41
seems nuts to buy a planing high speed hull then anti-foul it .......... arrrrgh
