It is currently 19 Jun 2026, 15:48
Servicing prices?
by Stevie101 » 30 Jan 2017, 12:36
I was having a conversation about the price of servicing of boats compared to cars and trucks.
I run 3 HGVs a couple of LGVs and a couple of cars and a a boat (V6 4.3ltr) and the difference charged between them for servicing is really interesting.
So I was just wondering as we are all over the country what you pay for your servicing on your boat?
I'll start!
Mine is booked in for April at an estimated cost of approx £350 for standard service + any additional parts and we are in South Yorkshire.
Stevie101
by ColinR » 30 Jan 2017, 14:55
That sounds about right for a V6 4.3. Based of South coast prices.
by BruceK » 30 Jan 2017, 16:58
lucky devil
by Ianfs » 30 Jan 2017, 17:04
Hopefully you had a mild winter on the canal and she didn't freeze. :) We had down to -5c on the South Coast so any plain fresh water may have frozen. From what you said previously I think you were debating whether or not to winterise her because you wanted to use her. As Colin said £350 would be there or thereabouts depending upon labour charge and what is deemed standard service.
I think you said you were handy with spanners, if so check this out......all priced as Genuine parts rounded up.
Engine Oil x 2 @ 3.8l each £60
Quicksilver oil filter £12
Quicksilver Fuel filter £10
Spark Plugs x 6 £21
2-4-C Grease £9
Gear Oil Sterndrive x 2 946ml £36
Lube pump £7
Washers for Sterndrive oil plugs 3.50
SUB TOTAL £158.50
If you want to drop the leg to inspect the impeller and gimbal bearing add these.....
Sterndrive Gasket set £15
Impeller £40
Anode Kit £66
Lube pump £7
Plus an impeller gasket or two.
Oh and a good oil suction pump, not a cheap and nasty one but a good Pela or similar.
by sprocker » 30 Jan 2017, 18:06
Last year - Single Suzuki Df115 - £353 (Main Dealer price as still under warranty).
This year - Twin VP D3 190's with outdrives - approximately 4 times the price.
by shibbs » 30 Jan 2017, 21:45
sprocker wrote:Last year - Single Suzuki Df115 - £353 (Main Dealer price as still under warranty).
Is that an annual service cost? :o
by Bigplumbs » 30 Jan 2017, 23:47
I know I will be shot down in flames here but I don't thing all the things people often do ever year need doing every year. Particularly 2 stroke outboards. For Example:
Fuel Filter will last 2 years
by sprocker » 31 Jan 2017, 07:51
This boat is new to me (Also VP/diesel new to me) so I wanted a full service on everything, including bellows etc, so I could be confident everything was correct.
It should be less next year, and I will also start to do my own servicing as I get used to the Volvo layout etc, so labor costs will be removed.
by betty boop » 31 Jan 2017, 08:50
no shots fired from here, definitely agree on those items, + a few others, if you fully investigate Mercrusier servicing procedures not what mercrusier agents recommend 'they carry out' the impeller for instance can go longer dependant on hours used and condition when inspected and replaced. Boats are in a harsher environment but a trailered boat used in the summer is easily DIY serviceable unless you have something to prove or way to busy etc.
On the original post that £350, I assume is the engine only not the Leg included?
by shibbs » 31 Jan 2017, 12:43
So can I ask, what would be the expected service cost for a normal annual service on a Diesel engine, excluding the drive leg etc?
