It is currently 19 Jun 2026, 11:36
Electric fuel pump
by NickT » 30 Oct 2016, 19:42
Hi chaps,
I have a problem with fuel starvation and I think I have narrowed the problem down to the fuel pumps.
As the engine is 16 years old I am finding it hard to source diaphragm repair kits so am considering bypassing the mechanical pumps and fitting an electric k&n pump.
Spec for the merc pumps is up to 7 psi and 67 litres an hour.
Multiply x 2 gives a throughput of around 134 litres an hour. Bearing in mind that my fuel tank is 80 litres and that would last for about 5 hrs I think the k&n pump at 160 litres/hr should more than cover the carbs requirements.
It is self priming and regulated plus I can dispense with the traditional squeeze bulb in the fuel line.
Does anyone have a view on any pitfalls please?
by Ianfs » 31 Oct 2016, 04:55
Only issue's I can see are, electric fuel pumps don't like running dry, also if your engine uses 80 litres in 5hrs that's 16 lph which is a lot less than 160 lph. Do you think the extra pressure/flow will affect the needle valves i.e. the extra pressure may cause flooding?
by NickT » 31 Oct 2016, 07:16
Hi Ian,
I don't know if that will be an issue.
The costs of repairing the existing pumps may well exceed the cost of an electric pump at£60 by a large margin.
I have contacted a mercury dealer to check spares availability and await their response.
Of course this may not solve the problem but would eliminate one aspect!
If this doesn't work then a strip and rebuild of 4 carbs in likely. If I do that then I may remove the air restrictor and fit larger jets to update to 90 hp at the same time. (Dennis thinks that I have rebadged a 115 merc anyway).
Good job the season is over as I would be champing at the bit with this fault...
by Ianfs » 31 Oct 2016, 08:45
Are you still getting die back?
by Gazjen » 02 Nov 2016, 20:17
Usually electric fuel pumps are wired through the oil pressure switch too so if the engine stops the pump does too.
Gazjen
