It is currently 05 Aug 2026, 08:06
by Stevie101 » 25 Sep 2016, 20:43
I use one of these. https://www.ebay.co.uk/itm/391212942947
It emptys a 20L can in 2/3 mins and you don't spill any.
Stevie101
by betty boop » 26 Sep 2016, 08:29
Octobver issue of Practical boat owner showed how to build a small pump from ebay bit n bobs for £10 - looks like the small 12v option to save you working to hard at pumping/sucking/siphoning.
by ChrisH » 26 Sep 2016, 17:41
betty boop wrote:Octobver issue of Practical boat owner showed how to build a small pump from ebay bit n bobs for £10 - looks like the small 12v option to save you working to hard at pumping/sucking/siphoning.
Like. Thanks
by Matt13 » 26 Sep 2016, 20:20
I bought one of those from the boat show a few years ago it's great, takes about 3-4 mins to empty a 20l can.
Make sure the end of the pipe will fit into the can as one of the ones I bought didn't.
Matt13
by ChrisH » 27 Sep 2016, 18:14
Matt13 wrote:I bought one of those from the boat show a few years ago it's great, takes about 3-4 mins to empty a 20l can.
by Ianfs » 02 Oct 2016, 15:47
How did you get on Chris, did you buy anything?
by ChrisH » 02 Oct 2016, 22:15
Ianfs wrote:How did you get on Chris, did you buy anything?
Not yet. But might try one of the syphon pumps Stevie101 posted.
Stevie101 wrote:I use one of these. https://www.ebay.co.uk/itm/391212942947
by ChrisH » 02 Oct 2016, 22:16
Not yet Ian. But might try one of the Syphon pumps Stevie101 posted.
by argonaut » 04 Oct 2016, 11:20
Sort of returning to the OP
by ColinR » 04 Oct 2016, 11:42
I have two jiggle tubes, the larger one will shift a 20ltr jerry can in under 2 mins, more like 1.
Bought one from the guy at the boat show and the other (cheaper) at Beaulieu boat jumble.
