It is currently 03 Feb 2026, 10:53
Got Scared
by Bigplumbs » 04 Oct 2015, 15:12
The River boat is ok but you still have the main costs which is £1500 marina and £500 + for Broads Licence. I aint paying that :)
by annageek » 04 Oct 2015, 16:48
We had a similar dilemma. Given our current boat (Fletcher 19gts) is our first boat, when we were looking into buying, we spent a lot of time seriously considering having something just about trailer-able to save the c. £2k per year 'on/at the water' storage costs.
We knew we wanted overnight facilities on board, and the smallest/lightest boat would have been something like the Fletcher 19GTO. We both drive hatchbacks, so one of us would have had to have changed to a smallish 4x4 like a Freelander if we were even to stand a chance of towing/launching/recovering safely, reliably and legally. In addition, we both have post 1997 driving licences, so can only tow up to 3.5t combined train weigh (without needing to do a towing licence) so we'd have had to have been pretty selective with the actual car we chose.
With all this in mind, combined with the extra cost of running a bigger car all the time (fuel, tax, insurance, tyres, servicing - all adds up!) the costs of trailer upkeep and the greater hassle of usage of the boat, we bit the bullet and stuck her in a dry stack. In fact, the hassle element was probably the biggest factor which lead us to make this decision. If we had gone down the towing route, I expect we would only have used our boat half as much as we have done with her in a dry stack.
but I'm pretty certain that a 3.0l stern drive engine weighs about 400kgs
I'm prepared to be proven wrong here, but I think this estimation may still be a bit OTT. The engine is about 234kg and the alpha one leg + transom assembly is about 54kg, so 288kg combined. Add on the trim pump, and I expect you're up to a nice round 300kg.
Anna will no doubt put you right on that sees :lol:
Yep, 1370kg fdry weight for the 19GTS (sterndrive versions).
What I find crazy is the fact that if you take the dry weight of an engineless GTO vs an engineless+driveless GTS, there's 220kg more weight in the GTS' hull (GTO = 850kg and GTS = 1070kg). I have always assumed this is because of the additional internal hull structure required to accept the inboard engine mounts in the GTS vs the GTO spec hull. Also, the GTO is only rated up to 150hp (or is it 130?) IIRC, whereas the GTS is rated up to 245hp., which I presume commands a stiffer/stronger transom.
We have a twin axle SBS trailer for ours, and I expect, with everything included (fuel, fluids, junk etc) on the trailer, we're looking at around 2000kg.
With all this said, I do agree with NickT though, that if you have a suitable vehicle, then a Fletcher 19GTO could be perfect. It just sounds like you will struggle a lot if you try and launch and (more crucially) recover with your present car. But then, if you do end up having to change your car to safely launch/recover, then why not just choose somethig that'll happily launch/recover a a GTS, such that you're not just limited to a rare breed of boat? Don't be too put off by the servicing costs of the inboard either. It's easy enough that even I have been able to keep ours running for the last three seasons! I'd say average £250/year (if you DIY) to cover standard servicing and a bit of preventative /ongoing maintenance. Some years will be cheaper, but some more expensive - like this year for us, where we have to do manifold+elbow, gimbal, bellows, carb rebuild, service and a couple of other bits - but it's just bad luck that its all occurring in the same year! It's certainly going to put my mechanical skills to the test!
by Bigplumbs » 04 Oct 2015, 18:30
Anna. Thanks for the excellent post. There is no dry stack near me and I am a mean boater so want to look more into the towing option but I note what you say. My other car that I use for my radio control plane hobby is a Toyota Previa That weighs in at 1800KG. It is an Automatic though so might be a bit of a pain on the slip.
by mlines » 04 Oct 2015, 19:50
Buy a cheap land rover discovery just for towing.
by Ianfs » 04 Oct 2015, 20:25
Ianfs said....
A fletcher GTO is about 1400kgs
Anna said.....
So at least I can hold my head up and take Nick's explanation... :D
Bless you for coming to my aid Nick, but I'm pretty certain that a 3.0l stern drive engine weighs about 400kgs and a 150 Mercury (to use as an example) weighs about 230kgs, a 170kg difference, so my estimation of 1900kgs all up was way out! :shock: :? Thank you anyway. :)
This is what I was trying to explain, therefore I guess you have some factory information. I thought a 3.0l Mercruiser weighed about 400kgs, but was proved wrong and sounds like the same as an outboard at 230kgs.
by annageek » 04 Oct 2015, 20:48
Its surprising actually, isn't it! I always thought our engine would have weighed more until I looked it up. Although, with a similarly sized outboard I suppose you do get the drive integrated for that weight.
by NickT » 04 Oct 2015, 21:46
I'm getting lost with all this maths!
130 HP is the Max rating for the gto Anna, but apart from Honda I don't know of any other manufacturer that makes them.
So a 115 4 stroke would be a good compromise. Having said that I think the etec engines from evinrude are lighter so a 150 may well be a good match.
I have no doubt that the extra 20 HP can be accommodated in terms of structural ability of the hull and transom.
As I can't afford either at the moment (son at uni =££££) I will just dream on.....
by _Ed_ » 04 Oct 2015, 22:18
My 2 stoke outboard is about 160Kg. No way on earth that they are anywhere near the weight of an iron block V6 or V8 :)
Also out of interest I have a LWB shogun to tow my 17ft Fletcher. On some of the slipways I use I'd struggle with anything less (!!!!!) also, on a weigh bridge I came in at 3560KG...
Boats usually weigh quite a bit more than you expect. I know mine did, and nearly got in trouble as a result (Now have +E so can relax).
by Gazjen » 05 Oct 2015, 01:42
I used to tow my Regal 2550 everywhere that was 25ft had a fridge and a 4 berth cuddly you could (almost) stand up in. You wouldn't pull it with a vectra though. It weighed 3360kg with the trailer.
I suspect a 3.0 with drive weighs more than 300kgs having lugged one about after a rebuild it certainly felt heavier. One thing I do know is a 5.7 v8 with duo prop drive weighs 732kgs
I'm on the casual look out for a Regal 2250 to use exactly how you describe towed about and used for rivers and the odd trip to the coast. Infact I'm after the exact same boat as Mlines :)
Gazjen
by Ianfs » 05 Oct 2015, 08:58
Here's one for sale......buy it. :mrgreen:
Needs a bit of TLC though.
Fletcher Sports Cruiser with Outboard
  • In total there are 607 users online :: 1 registered, 0 hidden and 606 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: Bing [Bot] and 606 guests
