It is currently 05 Aug 2026, 00:58
by sprocker » 08 Sep 2015, 18:47
Problem solved. Both isolator switches had worked loose on the centre screw so weren't opening fully on the cam.
I tightened them up and added a lock nut so that should stop them working loose again. Everything is now isolated in the OFF position.
by ColinR » 08 Sep 2015, 20:03
Result :)
by _Ed_ » 08 Sep 2015, 22:05
That's more like it!
by Ianfs » 09 Sep 2015, 07:03
Wise man, great result. :)
by sprocker » 09 Sep 2015, 07:28
I wonder how many have these switches that have worked loose but don't realise they are not isolating? An inherent design problem easily cured with a locking nut.
