It is currently 05 Aug 2026, 01:55
Help with fibreglass fishing boat
by Duggie12 » 23 Jun 2018, 08:34
Hi folks
I've bought a 12ft fibreglass fishing boat.
It has a bung on the outside of the transom - presumably to drain water from the inside of the boat when it is pulled out of the water
There is also a hole where a bung can be screwed in on the inside section but there is no bung there just now
Is it best to put a bung in the inside and just bail out the water from the inside? The boat is kept in the water the whole time
The hull seems to fill up with loads of rain water which keeps flooding into the bottom of the boat when I'm using it. I'm guessing there must be a big void under the floor where water can gather
Duggie12
by mlines » 24 Jun 2018, 17:21
Bungs should really be in the outside so the water pressure helps keep them in place
by shibbs » 24 Jun 2018, 21:18
Mine has internal bungs which all drain down into the engine bay, allows the water from inside to drain down, Not really sure on the point of them as in my opinion i'd rather and water that gathers ( ie people getting in from the water from swimming etc) would drain straight down there to be pumped out.
I wouldn't worry that its missing personally as long as you are there enough to make sure it gets pumped out regularly enough, especially if it is rain water that accumulates.
I may have missed the point but that is my understanding..
by ChrisH » 24 Jun 2018, 22:14
My Mariah had screw in brass plug externally at the base of the transom.
