It is currently 03 Feb 2026, 09:39
by Ianfs » 28 Jun 2015, 06:09
The first picture is the thrust washer, I thought it may come off with the prop. It sits on the drive shaft which is tapered and goes on first, so you'll have to put it back on the right way round. The other washer is the tab washer and behind that is a continuity washer.
You should also have another washer in which the nut sits and when tight the tabs go into the tab washer.
But like I said, you will need some grease either 2-4-c or 101. For all the parts.
If you need any more help just shout. :)
by Carl » 28 Jun 2015, 12:40
The locking tab washer is with the nut. ... I'm assuming the thrush washer and the tab washer just prise out ?? do I need any special tools to remove them.
by Ianfs » 28 Jun 2015, 18:49
Yep you're right they should just prise out with a screwdriver.
by Carl » 28 Jun 2015, 21:09
Ianfs wrote:Yep you're right they should just prise out with a screwdriver.
Excellent ... just what I wanted to hear. :D
by Carl » 29 Jun 2015, 12:16
Got them out ..... needed a puller to get the tall bit out ... ..
but anyway ... all the bits are cleaned up and ready to use in the new one. ..
by Ianfs » 29 Jun 2015, 13:33
I was just checking add from which you bought the prop to see if there should be a continuity washer and it says there should be a Flo Torq 11 kit with it.
Have another look in the box! :mrgreen:
by Carl » 29 Jun 2015, 14:00
It hasn't arrived here yet :( ... am expecting it either tomorrow or wed ...
by Ianfs » 29 Jun 2015, 18:35
So this prop sounds as if it comes from a good source, consequently it should fit on straight away!
Glad to be of assistance once again. :D
by Carl » 29 Jun 2015, 22:03
Ianfs wrote:So this prop sounds as if it comes from a good source, consequently it should fit on straight away!
I'm sure i'll see when it arrives ...... .. but yes! .. thank you for all your assistance. 8-) 8-)
by Carl » 30 Jun 2015, 14:39
New propeller arrived this morning .... :D
Didn't think much of the supplied internals though ..... (seen on the left ) ... so I re-used my original bits
And fitted ..... Testing is on Thursday eve when we launch her for a trip down the Dart
  • In total there are 234 users online :: 1 registered, 0 hidden and 233 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: Bing [Bot] and 233 guests
